drftorres
Jan 09, 2019Aspirant
Add another Orbi RBR20 router via LAN cord and still use same SSID
I have purchased two main RBR20 routers, one of them with 2 satellties and the other one with 1 satellite. My apartment is big, so satellites are not enough. My main fiber cable internet is located i...
drftorres
Can I use my Orbi router as an Orbi satellite?
Jan 09, 2019Guru - Experienced User
RBR routers can't be used as satellites. Only as the main host router or in main AP mode connected behind another router.
- drftorresJan 09, 2019Aspirant
I am using this configuration. Both are exactly the same routers.
- FURRYe38Jan 09, 2019Guru - Experienced User
Yes. the Blue topped router in the pick is the RBR, the White topped one is the RBS. That configuration works. You can add more satellites to that as well. Just can't use the RBR as a satellite. You can connect it up as a separate wifi AP, however they may post problems and it will make your wifi surroundings more noisy and can cause wifi connection problems if in the same home. It's best to keep to 1 RBR and use satellites were needed.
30 feet is recommended in between them to begin with depending upon building materials.
5,000, concrete walls
