kacnps
Mar 30, 2020Aspirant
Add Netgear C3000 on Orbi mesh RBK040
Is it possible to add the C3000 to my Orbi Mesh RBK040 system as an extender or access point? One of my nest cameras that is outside is losing signal occasionally and would like to strengthen the s...
- Mar 31, 2020
The CM700 would be best.
Mar 30, 2020Guru - Experienced User
No, the C series mode can only work as a router modem or just as a modem when in bridge mode.
kacnps
Mar 31, 2020Aspirant
Thanks - what about the CM700? That's what's currently on my modem and Orbi attached to - I could switch it out with the C3000.
- FURRYe38Mar 31, 2020Guru - Experienced User
The CM700 would be preferred as it doesn't have a built in router and wifi.
- kacnpsMar 31, 2020Aspirant
Oh, I see it's a cable modem only..... but just as an aside - would the cm700 or the c3000 be the better product to work with Orbi Mesh RBK40?
