officialdjdmc
Feb 26, 2022Follower
Add new phone number for Orbi
I need to update my cell. It is not intuitive on how to change my cell in the app or on my NG account. Ultimetly I need to update my cell number update my password Login into my circle ...
Feb 26, 2022Guru - Experienced User
Change any NG account information here:
https://www.netgear.com/support/#
You may need to contact NG support to help you with Circle account informaton:
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
Or:
https://my.netgear.com/support/contact.aspx
Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle product. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
