KyleFinke's avatar
KyleFinke
Add on or replace
I bought a AC3000 (RBK50) in 2017 and am moving to a larger home. I wanted to add on another satellite but I'm not sure if any of the new ones are backward compatible. Should I buy another satellite ...
  • FURRYe38's avatar
    The RBR and 1 RBS would be enough, depending on building material however. Wood and sheet rock is ok. Concrete and steel will inhibit wifi signal travel.
    Placement and distance of the RBR and RBS is important for good operation. 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Also can be too much wifi signal in the home as well:
    https://youtu.be/UR0viMLISz4
    I would first try the RBK50 in the new home out first then see if you need to add another RBS.
