dcubas's avatar
dcubas
Follower
Apr 23, 2019
Add-on Orbi Outdoor Satellite (RBS50Y) Compatible with RBK53
Hello everyone,
Somebody happens to know if the Add-on Orbi Outdoor Satellite (RBS50Y) is Compatible with RBK53 AC3000, i was looking in the datasheet and it seems that the answer its no, just want to make sure before buying them. thanks in advance
1 Reply
  • FURRYe38's avatar
    Yes, The RBSY requires a Orbi system like the RBK53.
