Ravisdavis
Mar 04, 2018Follower
Add on rbs40 speed with rbk50
I think i know the answer but want to be sure... Have the rbk50 and want to add maybe an rbs40 and connect that through ethernet to ps4 and maybe the tv. Is the backhaul speed of the satellite 866 or...
Mar 04, 2018Guru - Experienced User
THe RBS differ in connetion rate and some features. Actual data flow should be good however the RBS unit seem to match what eack RBK router supports and handles in regards to conection rates. You might want to keep same matching models for your router.
Ravisdaviswrote:I think i know the answer but want to be sure... Have the rbk50 and want to add maybe an rbs40 and connect that through ethernet to ps4 and maybe the tv. Is the backhaul speed of the satellite 866 or does that just apply to the rbk40 router?
Guess what I'm asking is will the rbs40 slow down any part of the network, especially if the satellites daisy chain? Just thinking of an addon rbs40 over an rbs50 for cost reasons. I don't have the option to run ethernet cable to any of the satellites for a wired backhaul. Thanks.
