robinsonktm
Sep 11, 2018Aspirant
Add on satellite VC3000 RBS50Y in stead RBK50
I wan to Add satellite VC3000 RBS50Y in stead RBK50, can i do that and also can i add more than 3 satellites.
Sep 11, 2018Guru - Experienced User
The RBS50Y is a outdoors satellite only. Not a router. You still need the RBR50 as the main base wifi router.
- robinsonktmSep 11, 2018AspirantOh Yes, I am already using RBR50 with two satellites and wanted to add one more to cover up my area. So later I came to know RBS50Y can go with it. And do I need connect with the main router as it seems on the main website Main router extend to RBS50Y and if I add another RBS50Y then it bridges from 1st RBS50Y. Like for eg Main router —->RBS50Y —-> 2nd RBS50Y as per video template shown on the NetGear page. Please clarify
- FURRYe38Sep 11, 2018Guru - Experienced User
Yes you'll need to connect the RBS50Y to the main RBR router. I believe if you enable Daisy Chain on the RBR then connecting two RBS50Y will be connected as you describe.
Thank you so much for your quick response on my query and appreciate your positive reply..
Once i got RBS50Y then i will definitely do the same, will order by tomorrow and for delivery it may take time...
