robinsonktm
Sep 11, 2018Aspirant
Add on satellite VC3000 RBS50Y in stead RBK50
I wan to Add satellite VC3000 RBS50Y in stead RBK50, can i do that and also can i add more than 3 satellites.
robinsonktm
Oh Yes, I am already using RBR50 with two satellites and wanted to add one more to cover up my area. So later I came to know RBS50Y can go with it. And do I need connect with the main router as it seems on the main website Main router extend to RBS50Y and if I add another RBS50Y then it bridges from 1st RBS50Y. Like for eg Main router —->RBS50Y —-> 2nd RBS50Y as per video template shown on the NetGear page. Please clarify
Sep 11, 2018Guru - Experienced User
Yes you'll need to connect the RBS50Y to the main RBR router. I believe if you enable Daisy Chain on the RBR then connecting two RBS50Y will be connected as you describe.
- robinsonktmSep 11, 2018Aspirant
Thank you so much for your quick response on my query and appreciate your positive reply..
Once i got RBS50Y then i will definitely do the same, will order by tomorrow and for delivery it may take time...
- FURRYe38Sep 11, 2018Guru - Experienced User
Good Luck. :smileywink:
