robinsonktm
Sep 11, 2018Aspirant
Add on satellite VC3000 RBS50Y in stead RBK50
I wan to Add satellite VC3000 RBS50Y in stead RBK50, can i do that and also can i add more than 3 satellites.
robinsonktm
Thank you so much for your quick response on my query and appreciate your positive reply..
Once i got RBS50Y then i will definitely do the same, will order by tomorrow and for delivery it may take time...
Sep 11, 2018Guru - Experienced User
Good Luck. :smileywink:
