jkpolack24
Dec 01, 2019Tutor
Add Orbi Modem to Existing Orbi Network
I have an existing network setup that includes an RBR20 and and RBS20. They are connected to the internet through older Arris Modem/Router. The current setup has the RBR20 in AP mode. I'd like to rep...
CrimpOn
Dec 01, 2019Guru - Experienced User
The answer is "No" (and "sort of")
The RBR20 (router) can only function as the "router" in an Orbi system. It can never be a "satellite." By purchasing an Orbi CBR40 (cable modem/router/WiFi), you can eliminate the Arris as long as the Orbi is compatible with the ISP. You will still have one router and one satellite.
The left-over RBR20 CAN be placed in Access Point (AP) mode and connected to the new router. It will function just like any WiFi access point of any brand. It will not integrate or coordinate with the Orbi system. i.e. devices will not "roam" from Orbi to this (or back). It would cost a ton less to purchase ordinary WiFi access points (from anybody. heck buy two or three. But, you will no longer have a "mesh" system. Getting a mesh instead of a collection of access points was why mesh systems were created.
My advice: don't do it.
