thecos77
Aug 30, 2019Aspirant
add satellite , reposition, or upgrade desktop
My ORBI has great WiFi signal throughout my 2 story home, including the second floor, on all of my devices except an older desktop HP located on the 2nd floor. As I write this, download speed on my d...
Aug 30, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What is the Mfr and model# of the wifi adapter in the desktop PC?
You should see status of the wifi connection under the networking settings in windows.
Can the PC be wire LAN connected to the system?
thecos77 wrote:My ORBI has great WiFi signal throughout my 2 story home, including the second floor, on all of my devices except an older desktop HP located on the 2nd floor. As I write this, download speed on my desktop is 39 Mbps, while on my apple phone, it is about 400 Mbps. I would like to improve WiFi speed on my desktop. I could add an additional satellite, move the current satellite, or upgrade my computer which is maybe 6 years old running windows 10. I cant figure out how to determine what version of WiFi this desktop is running. What would be the best way to proceed? thanks
thecos77
thecos77
Firmware V2.3.5.26
Arris SurfBoard Model SB6190
Sq Footage 2400
Broadcom 802.11n wireless adapter
Router to Satellite Distance, about 30 feet ,signal passes thru one wall
NOT able to run cable to this computer
Thanks, thecos77
- FURRYe38Aug 30, 2019Guru - Experienced User
Is there a model# of this adapter?
Is the wifi drivers for this adapter up to date?
How old is the PC?- CrimpOnAug 30, 2019Guru - Experienced User
I'm embarassed that I did not read the original post carefully. A six year old computer does qualify as "not new", but is not ancient. 801.11n should be capable of more than 39mb. If the iPhone achieves 400mb close to the computer, that would indicate that the 5G signal is good and that a 5G USB WiFi adapter might be a quick way to solve the problem inexpensively. Amazon has them for under $25. (Just personally, I would go with a "Brand Name" like TP-Link.)
802.11 can be compromised when there is a device somewhere on the network that is only capable of 802.11b. That forces the entire network to drop to 802.11b speed. A thermostat would not suffer. A computer certainly would.
- thecos77Aug 30, 2019Aspirant
thanks for the tip, I will upgrade the wifi adapter, and post results
thecos77
