kennethjart
Nov 30, 2019Tutor
Add Satellite Bandwidth?
We have Orbi RB50 router+two satellites (that's 2-3yrs old). We experience buffering in some places of 1800 sq ft older home (with plaster walls). We cannot put router in center of home. If we add...
Nov 30, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
kennethjart wrote:We have Orbi RB50 router+two satellites (that's 2-3yrs old). We experience buffering in some places of 1800 sq ft older home (with plaster walls). We cannot put router in center of home. If we add a satellite, how much does this affect signal strength? Weakens it? Lowers bandwidth? Good idea? Bad idea? Thanks.
kennethjart
Nov 30, 2019Tutor
Thanks for all the info đđŒ
- FURRYe38Nov 30, 2019Guru - Experienced User
Hope this helps...
