Tomy28
Sep 08, 2022Aspirant
add satellite(s) to existing RBK 23
Hello I own an RBK 23 set-up with an RBR 20 router and 2 RBS20 satellites. I would like to buy additional satellite(s): which model(s) are compatible? Thank you
- Sep 09, 2022Yes, packages are much more price effective that buying only satellites. I bought two sets of RBK52 (router + 2 satellites) for around 250 USD each set. So even if I won’t use the router, I got 4 satellites that didn’t cost more than 125 USD each.
ekhalil
Sep 09, 2022Master
Any Orbi AC satellite will work: RBS20, RBS50, RBS10, RBW30, RBS40, RBS40V (Satellite with built-in Amazon Alexa), RBS50Y (Outdoor satellite).
Good luck!
- Tomy28Sep 09, 2022Aspirant
Thank you but which of those are actually on sale?
- ekhalilSep 09, 2022Master
Tomy28 wrote:Thank you but which of those are actually on sale?
It depends where you are. 🙂 Here in Europe I can find and buy the RBS20, RBS50, RBS40V and RBS50Y in quite many places.
The RBS50 -particularily- is available at very good reduced prices.
Thanks for your help!
I'm in France. I'm indeed finding the RBS50 but only 20% cheaper than I bought the whole set of router + 2 satellites, 2 years ago. Also, I'm surprised not to find it on netgear's website directly (nor where I bought the original set).
