clevend's avatar
clevend
Follower
Jul 25, 2022
Added a second satellite and now the connection is terrible.
I have the RBR50 router and have had just one RBS50 satellite for rhe past couple years. It's worked great until yesterday when I added a second RBS50 to cover my backyard. I get connection in my backyard now but the connection in the house is so spotty and jumpy. My nest keeps saying it's disconnected, I have issues with PC's that are plugged in to a satellite. What gives?
1 Reply
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Too Much Wifi: https://youtu.be/UR0viMLISz4
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
