GMHunter
May 23, 2020Aspirant
Added RBS50 is Sync'd, Had IP address but IP/Bakhaul doesn't show in GNU
I purchased a used Orbi RBS50 to add a 3rd to my existing system that includes the RBR50 and two RBS50 units supplied with the original system. The 3rd RBS50 easily sync'd and showed in GNU as 3rd s...
CrimpOn
May 23, 2020Guru - Experienced User
"GNU" is short for ???
Just a tiny bit of terminolory. "Backhaul" is the term for communication between satellites and Orbi router. Backhaul can be WiFi or ethernet, and there can be a mix. Some satellite backhaul can be WiFi and some can be ethernet.
When the satellite is powered up, the ring light should follow the pattern described in this web page:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
If the last "color" seen is a solid blue light, then the satellite has in fact connected to the router with a "good" connection.
GMHunter
GNU is what I thought this forum has been refering to the RBR50 Orbilogin.net application, it says that at teh bottom. The 3rd device does go thorugh the start up and flashes blue at the end but isn't connecting any devices nor is it doing more than a switch with regards to passing through wired internet; must be wired to router to allow wired device to get connected.
The lack of an assigned IP address in the RBR50 Obilogin.net is different than when first connected with a different, earlier firmware version in the 3rd RBS50. After firmware upgrade to match rest of my Orbi system, the IP address that was visible is now gone. Never got it communicating with different firmeware versions so I am thinking that going back to original is wrong direction.
- CrimpOnMay 23, 2020Guru - Experienced User
GMHunter wrote:GNU is what I thought this forum has been refering to the RBR50 Orbilogin.net application, it says that at teh bottom. The 3rd device does go thorugh the start up and flashes blue at the end but isn't connecting any devices nor is it doing more than a switch with regards to passing through wired internet; must be wired to router to allow wired device to get connected.
Thanks for the explanation about "GNU". Actually, Netgear is explaining that the Orbi software is issued under the GNU license because it is based on OpenWRT, which is open source software. It has a nice ring to it. I usually describe "Orbi web interface" vs. Orbi "app" (which is nearly worthless in my opinion).
My usual tactic is to do bring the satellite into the same room with the router (which avoids running back and forth), no ethernet cable for now, perform a "Factory Reset" on the satellite https://www.youtube.com/watch?v=cMw4ePACgc4 , then open the Orbi web interface and select "Add Orbi Satellite" (bottom menu item). Until the satellite properly syncs with the router over WiFi, there is little point to attempting ethernet connection. Once the WiFi backhaul is working correctly (satellite appears on Attached Devices), then an ethernet patch cable can be plugged in.
Attached Devices does not update instantly I switched a laptop from ethernet to WiFi and it still showed up as connected for several minutes even though the cable was clearly unplugged. The process of checking connections and updating Attached Devices appears to have several "timers" running. Just in general, I find that computers are not very "fast" about doing things like starting up, updating, etc.
It is generally felt that the best practice is to have all Orbi units on the same firmware.
If you can give it another try, please describe what happens this time.
- GMHunterMay 23, 2020Aspirant
Also in the RBR50 OrbiLogin.Net in the list with "connected satellites" it shows the 3rd just added RBS50 but no IP address, has its correct MAC but "connection type" and "connected orbi" have just a dash. Again, the Backhaul Status has Disconnected with a button to remove.
Sorry, I replied without seeing your reply. I have factory resent the new RBS50 satellite a few times without wire, do I need to also reset the router (RBR50) like in the video? If I resent the RBR50, will I need to also reset Sat#1 and Sat#2? Thanks for patience and help!
No need to reset the router. (I should have mentioned that. Sorry.)
Please "delete" the satellite from the display before trying to add it.
