beguna1
Apr 16, 2022Tutor
Adding 2nd satellite brings down network intermittently
I've had my Orbi and 2 satellites for years with no problems when they operated in Access Point mode. Last September, Google Fiber replaced their modem/router with a modem and I changed the Orbit to...
FreedomII
Oct 19, 2022Aspirant
Have you found a resolution to the problem? I have the same setup. One RBR50 router and two RBS50 satellites hard-wired for backhaul to the router. I had one router and one satellite working fine for years. I added the second and not I have issues. The WiFi will work fine for hours, but all of a sudden the wifi will stop working. Technically the wifi still works, but there is no route to the internet. The router and the other satellite and associated devices via wifi work fine. Devices connected to the satellite's ethernet ports also continue to work fine.
All firmware is up-to-date and on the same version
I have tried to re-sync the satellites and the router
Any suggestions?
Thanks,
Ethan
Oct 19, 2022Guru - Experienced User
What Firmware version is currently loaded? Be sure RBS have same FW version as RBR.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are the RBS ethernet connected directly behind the RBR or is there a LAN switch or LAN Patch panel in between them?
What CAT# lan cables are you using? Good quality CAT6 LAN cable is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try swapping RBS locations with each other to see if problem continues.
Try bringing both RBS to same room as RBR and ethernet connect them directly behind the RBR to see if the problem continues.
Any suggestions?
Thanks,
Ethan
- FreedomIIOct 19, 2022Aspirant
Firmware is the same on all three devices - V2.7.4.24
Using Verizon FiOS not sure of the ONT manufacture
All cabling is CAT 5e or better
Both satellites are hard-wired directly back to the router
Wood frame house, about 2300sq/ft
There is more than 30ft between each of the Orbi devices.
I have swapped the location of the RBS(s)
- beguna1Oct 19, 2022Tutor
More details of what I saw when I looked at the router's built in website. After years of working fine, when they started screwing up, I could see at the website that they took turns connecting and disconnecting over a matter of minutes. So I tried unplugging one satellite and the other satellite stayed up fine. So then I reconnected that one and unplugged the other one and that second one stayed up fine. So that told me my Ethernet wiring was perfect. So I reconnected them both and they work for a few minutes and then started taking turns disconnecting. So that told me I was wasting my time and I switched to the Google Wifi product. Whether it is a defect in the Orbi or an incompatibility with the Google Fiber I have, or sensitivity to a developing defect in the Google Fiber modem, I can't say. But I tried two more satellites that I had bought from Woot and they did not work either.
- FURRYe38Oct 19, 2022Guru - Experienced User
OK.
Have you factory reset the RBR and RBS and then setup from scratch, wirelessly syncing the RBS to the RBS one at a time, while in same room or fairly close in next door room to see if both RBS will connect wirelessly to the RBR and if network is stable here?I would give this a try first...
IF the RBS can connect to the RBR and things are ok at this point, then take a lan cable and connect up the RBS to the back of the RBR one at a time. Wait for the top ring to turn BLUE on the first RBS, then connect the 2nd RBS via ethernet. Wait for BLUE to turn ON then go off. Check RBR and network stability.
Yes. I have resorted to the factory reset and clean rebuild. I have spent some time (way too much time). Testing out the setting of:
- Daisy Chain Topology: Disabled (exception: if you have 3 or more satellites)
