DrPlano
Apr 26, 2019Aspirant
Adding 3rd RBW30 Satellite to RBR40 Router
I have an RBR40 router with two RBW30 satellites in a large, 3-story older home (lathe & plaster walls). System has been working OK for ~5 months, but there are a few weak spots where I would like be...
- Apr 27, 2019
here's what I'd do.
1. Reset the RBW30. Hold the reset button for 7-10 seconds.
2. power down your other satellites. Sometimes this helps during setup. You can power them back up after setup.
3. First try the adapter at about a 30ft distance. This is the mimimum recommended distance once setup. If it doesn't work, then move it to the same room. You can have it in same room for setup but once its setup, 30ft is recommended.
4. Plug in the RBW30. wait for it to fully boot. around 2 minutes.
5. regardless if the ring led is magenta or white upon fully booting, press the sync button on the back of the RBR40 router first. Within 2 minutes, press the sync button on the rbw30.
6. were you able to set it up? If so, move it to the location that you desire.
7. Unable? What happened? led's etc.
Here's the support page the the RBW30. it also includes the quick install guide that shows how to install it via the app. have you tried using both the app and the browser?
https://www.netgear.com/support/product/RBW30.aspx
Apr 27, 2019Guru - Experienced User
here's what I'd do.
DrPlano
May 04, 2019Aspirant
plemans -
Worked great! Sorry to take so long to reply - have not been the office long enough until today to perform the test.
As per your suggestions I:
- Reset Satellite-3 (the new one)
- Unplugged existing Satellite-1 and Satellite-2
- Plugged in Satellite-3 ~30 feet from Orbi router. LED flashing white for ~4 minutes then went to solid magenta
- Pressed and released Sync button on Satellite-3. LED flashing white again.
- Pressed and released Sync buttom on Orbi router within 15 seconds.
- LED light on Satellite-3 went to solid blue within ~1 minute.
- Checked orbilogin.net and it showed Satellite-3 status as "Good"
- After ~2 minutes LED on Satellite-3 went to flashing white again: on orbilogin.net status of Satellite-3 showed as "Disconnected", but then changed to "Good."
- Plugged in Satellite-1 and waited for flashing white light to change to blue (~3 minutes). Sstatus of Satellite-3 showed up on orbilogin.net as "Good."
- Rinse & repeat with Satellite-2 - same result (status "Good").
- Moved Satellite-3 from test location to target location. Once booted, Status also "Good".
Thanks again for you help .
DrPlano
- plemansMay 05, 2019Guru - Experienced User
Glad to hear you got it working and that I could help!
