VirtualDataBase
Sep 24, 2018Aspirant
adding 3rd satellite(outdoor)
I have an Orbi with 2 satellites... working..
I just tried adding a 3rd (outdoor satellite) but it fails to sync.. not much to go on.. just fails what could it be?
Sep 24, 2018Guru - Experienced User
Is the FW up to date on the outdoor satellite?
What is the distance between the outdoor satellite and base router?
Have you tried connecting the outdoor satellite in the same room as the base router and set it up there, then once connected, power off the satellite and move it to the out door location.
- VirtualDataBaseSep 24, 2018Aspirant
outdoor satellite firmware unknown.. cant get far enough (per instructions) to ever see it.
I've only tried setting it up in the same room as the base router...
flashes white for awhile then just purple (without me ever "SYNCing").. never goes white in order for me to sync.
