VirtualDataBase
Sep 24, 2018Aspirant
adding 3rd satellite(outdoor)
I have an Orbi with 2 satellites... working..
I just tried adding a 3rd (outdoor satellite) but it fails to sync.. not much to go on.. just fails what could it be?
Sep 24, 2018Guru - Experienced User
Can you try this?
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
- VirtualDataBaseSep 24, 2018Aspirant
This is NOT possible. The outdoor satellite has NO RJ45 ports.
- Christian_RSep 24, 2018NETGEAR Employee Retired
Hi VirtualDataBase,
I have sent you a message. Please respond at your earliest convenience.
~Christian
- naseerkhanSep 24, 2018Guide
I'm about to open packaging on a new Outdoor Satellite from Amazon, and I have the Orbi with 2 Satellites currently installed. So exactly in the same boat as the OP. Is there something I should know about problems with putting in an Outdoor Satellite as third satellite before I start?
I can still return to Amazon if this is not a good configuration. Didn't think about the fact the outdoor version won't have a RJ45 jack to get to it directly... that could be a problem.
Hello naseerkhan,
You should not have any issues syncing your Outdoor Satellite to your existing Orbi system. Please refer to the link below to manually sync your Outdoor Satellite:
~Christian
- naseerkhanSep 26, 2018Guide
Hi Christian,
Thanks for the link. I'll give it a try soon. I'd held off till I heard further and didn't have chance to see further forum posts till just now. Glad to see the OP got it working too...
--Naseer
