VirtualDataBase
Sep 24, 2018Aspirant
adding 3rd satellite(outdoor)
I have an Orbi with 2 satellites... working..
I just tried adding a 3rd (outdoor satellite) but it fails to sync.. not much to go on.. just fails what could it be?
Sep 24, 2018Guru - Experienced User
Can you try this?
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
VirtualDataBase
This is NOT possible. The outdoor satellite has NO RJ45 ports.
- Christian_RSep 24, 2018NETGEAR Employee Retired
Hi VirtualDataBase,
I have sent you a message. Please respond at your earliest convenience.
~Christian
- naseerkhanSep 24, 2018Guide
I'm about to open packaging on a new Outdoor Satellite from Amazon, and I have the Orbi with 2 Satellites currently installed. So exactly in the same boat as the OP. Is there something I should know about problems with putting in an Outdoor Satellite as third satellite before I start?
I can still return to Amazon if this is not a good configuration. Didn't think about the fact the outdoor version won't have a RJ45 jack to get to it directly... that could be a problem.
- VirtualDataBaseSep 25, 2018Aspirant
Got it working... had to call support but through a series of reboots and manual SYNC's it's working!
Hello naseerkhan,
You should not have any issues syncing your Outdoor Satellite to your existing Orbi system. Please refer to the link below to manually sync your Outdoor Satellite:
~Christian
- naseerkhanSep 26, 2018Guide
Hi Christian,
Thanks for the link. I'll give it a try soon. I'd held off till I heard further and didn't have chance to see further forum posts till just now. Glad to see the OP got it working too...
--Naseer
- FURRYe38Sep 27, 2018Guru - Experienced User
Let us know how it goes.
naseerkhan wrote:
Hi Christian,
--Naseer
