VirtualDataBase
Sep 24, 2018Aspirant
adding 3rd satellite(outdoor)
I have an Orbi with 2 satellites... working..
I just tried adding a 3rd (outdoor satellite) but it fails to sync.. not much to go on.. just fails what could it be?
VirtualDataBase
This is NOT possible. The outdoor satellite has NO RJ45 ports.
Christian_R
Sep 24, 2018NETGEAR Employee Retired
Hi VirtualDataBase,
I have sent you a message. Please respond at your earliest convenience.
~Christian
- naseerkhanSep 24, 2018Guide
I'm about to open packaging on a new Outdoor Satellite from Amazon, and I have the Orbi with 2 Satellites currently installed. So exactly in the same boat as the OP. Is there something I should know about problems with putting in an Outdoor Satellite as third satellite before I start?
I can still return to Amazon if this is not a good configuration. Didn't think about the fact the outdoor version won't have a RJ45 jack to get to it directly... that could be a problem.
- VirtualDataBaseSep 25, 2018Aspirant
Got it working... had to call support but through a series of reboots and manual SYNC's it's working!
- FURRYe38Sep 25, 2018Guru - Experienced User
Enjoy. :smileywink:
