Hsaag
Sep 13, 2017Aspirant
Adding a 4th satellite
I know that officially the system only takes 3 satellites and I was advised that a software update may be released to extend the ability for 4th but I am getting conflicting info from net gear. Can a...
DarrenM
Sep 13, 2017Sr. NETGEAR Moderator
Hello Hsaag
It is recommended to use 3 but users have had 4 work just fine and there is nothing special to the setup you do the same methods to connect a satellite normally.
DarrenM
Hsaag
i did try to add the forth but it wouldn't let me set it up. I didnt get a stable white light to then sync
- DarrenMSep 13, 2017Sr. NETGEAR Moderator
Try to factory reset that unit and then try to sync it in the same room as the main router. Also you may need to plug a cord into the unit itself and log into the gui and do a manual update of the firmware if it does not sync.
DarrenM
- HsaagSep 13, 2017AspirantThank you so so much , but what cord and what is a GUI when I said I'm untechnical I really meant it!
Factory settings is the reset button ?
Thanks for your grlp- DarrenMSep 13, 2017Sr. NETGEAR Moderator
Yes hold the reset button for 10 seconds on the unit. And i am talking about a ethernet cord and then log into the satellite.
DarrenM
