DigitalMan2112
Sep 01, 2020Tutor
Adding a access point?
I currently have an Orbi system with 2 satellites. The main Orbi and 1 sattelite are on the main floor and the second satellite is in middle of second floor. In the finished basement there is spotty ...
- Sep 01, 2020
I've got 4 satellites running right now. And I've seen up to 6x on the forums. Official support I believe is 3 satellites.
It works well, expecially when hardwired in.
Sep 01, 2020Guru - Experienced User
You'd add another satellite. You can hardwire in the satellites (except the rbw30, no ethernet connection).
- DigitalMan2112Sep 01, 2020Tutor
You can add a 3rd satellite? I thought it was limited to 2?
- plemansSep 01, 2020Guru - Experienced User
