ami_sin
Dec 22, 2020Aspirant
Adding a MESH to Nighthawk C7800
Hi I have the Nighthawk C7800 which was pworking great with my apartment with 940 MBPS, used primarily for streaming and ~50 connected devices. Now I have moved to a 2800 sq feet home, which has...
Dec 22, 2020Guru - Experienced User
You can add EX7700 or EX8000 extenders to the C series gateway modem, or turn OFF the router and wifi portion of the modem and use it as a modem only and connect up a Orbi system, AC or AX.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- ami_sinDec 22, 2020Aspirant
The descriptor on the extenders not 50 devices, and I have ~150 devices, so I guess that doesn't work, adn my only option is to go for the mesh
Will placing tmodem and satellite within 2o feet create interference?
- FURRYe38Dec 22, 2020Guru - Experienced User
Extenders would work as well to help with off loading your amount of wifi devices all connected to the modem.
- ami_sinJan 20, 2021Aspirant
Tried the EX7700, slowed everything down...ordered the Orbi Ultra-Performance Mesh WiFi System - AX6000 - 3 pack adn will likely use the C7800 as modem
- FURRYe38Jan 20, 2021Guru - Experienced User
Thanks for letting us know.
Please visit and post about this over inthe Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
