Stpeteguy
May 18, 2019Aspirant
Adding a Orbi to existing system
I currently have a RBR40 system & 2 RbW30 satellites. System works great.
I recently sold a home & it had the exact same system (3pc).
I know want to use the 2 satellites from other system with...
ekhalil
May 18, 2019Master
You just need to sync the “new” Satellites with the Router.
Push the sync button on the first Satellite and the sync button on the Router, wait few minutes until the LED ring turns blue.
Repeat then the same with the second Satellite.
Good luck
Good luck
- StpeteguyMay 18, 2019Aspirant
Thanks. It worked. 👊🕺👍
