Auggie11
Jan 25, 2020Aspirant
Adding a satellite
Hi, I currently have the below system that has two wall plug satellites. I would like to know if I can add the RBS50 satallite as I have LAN connections in many rooms. Will it work with my existin...
CrimpOn
Jan 25, 2020Guru - Experienced User
Yes. All Orbi satellites can be used with all Orbi routers.
- FURRYe38Jan 25, 2020Guru - Experienced User
Orbi AC satellites are not compaible with Orbi AX systems currently. NG is supposed to make them compatible. I believe some of them and not all. No time frame on when this will happen.
