Auggie11
Jan 25, 2020Aspirant
Adding a satellite
Hi, I currently have the below system that has two wall plug satellites. I would like to know if I can add the RBS50 satallite as I have LAN connections in many rooms. Will it work with my existin...
CrimpOn
Jan 25, 2020Guru - Experienced User
Yes. All Orbi satellites can be used with all Orbi routers.
Orbi AC satellites are not compaible with Orbi AX systems currently. NG is supposed to make them compatible. I believe some of them and not all. No time frame on when this will happen.
