geocod
Aug 19, 2024Aspirant
Adding a switch to RBR10
Added a 7 port gigabit switch downstream of the RBR10 and not getting any connection through it to lan to wired home security system need some help suggestions Thanks
michaelkenward
Aug 20, 2024Guru - Experienced User
Can you connect the security system to the RBR10 without the switch?
Does anything else work when connected to the switch?
There are three things involved there, router, switch and security system. Answers to these questions will help to pin down the problem.
Just another user with time on their hands.
geocod
Aug 20, 2024Aspirant
security system connects when direct connected to RBR10 lan port, all other connections through switch work , need the extra lan connections as RBR was only 1 port
Thanks
