Gizmoguycdn
Jun 22, 2018Aspirant
Adding a third satelite
I have an RBR50 router and two satellites. One is an RBD50 and the other is an RB50. I am getting connection issues with one side of the house and want to add a third Satelite. Should I buy an RB50 or...
Jun 22, 2018Guru - Experienced User
RBK50 should have RBS 50s in the kit believe.
At any rate, RBS50 would be best suited....
- GizmoguycdnJun 22, 2018AspirantThank you for the reply. So what’s the difference between an RB50 and an RBS50 Satelite ?
- DarrenMJun 22, 2018Sr. NETGEAR Moderator
It should be RBS50 all over the world.
DarrenM
- GizmoguycdnJun 22, 2018AspirantThank Darren, so I have an RBR50 with two Satelite RBS50. One of the Satelite is upstairs in my house. It has a weak connection with the router no matter where I place it and occasional would disconnect . Should I get another RBS50 to extend the range of the RbR50 to the upstairs Satelite ? Or should I buy a range extender and if so which range extender should I get?
