Gizmoguycdn
Jun 22, 2018Aspirant
Adding a third satelite
I have an RBR50 router and two satellites. One is an RBD50 and the other is an RB50. I am getting connection issues with one side of the house and want to add a third Satelite. Should I buy an RB50 or...
Jun 22, 2018Guru - Experienced User
RBK50 should have RBS 50s in the kit believe.
At any rate, RBS50 would be best suited....
Gizmoguycdn
Thank you for the reply. So what’s the difference between an RB50 and an RBS50 Satelite ?
