Gizmoguycdn
Jun 22, 2018Aspirant
Adding a third satelite
I have an RBR50 router and two satellites. One is an RBD50 and the other is an RB50. I am getting connection issues with one side of the house and want to add a third Satelite. Should I buy an RB50 or...
Jun 22, 2018Guru - Experienced User
Have you tried enabling Daisy Chain with your two satellites?
Gizmoguycdn wrote:
I have an RBR50 router and two satellites. One is an RBD50 and the other is an RB50. I am getting connection issues with one side of the house and want to add a third Satelite. Should I buy an RB50 or an RBS50?
Gizmoguycdn
Hi, how would I enable the two RBS50 to daisy chain? Though actually I don’t know if that would help as they are not close and there are some concrete walls separating them. I am interested to learn how to daisy chain in case I buy a third Satelite.
