Gizmoguycdn
Jun 22, 2018Aspirant
Adding a third satelite
I have an RBR50 router and two satellites. One is an RBD50 and the other is an RB50. I am getting connection issues with one side of the house and want to add a third Satelite. Should I buy an RB50 or...
Jun 22, 2018Guru - Experienced User
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
If you have some concrete in the middle, this will be a factor. Building materials can effect signals. Especially on 5Ghz.
May need to move them close to each other.
Any chance of running CAT6 buried LAN cableing between buildings?
Gizmoguycdn
Hi Darren, I read the article. It does not tell me how to configure the Orbi satellites to daisy chain. Is it automatic or do I manually have to configure it either to be in star or a daisy chain topology?
