Gizmoguycdn
Jun 22, 2018Aspirant
Adding a third satelite
I have an RBR50 router and two satellites. One is an RBD50 and the other is an RB50. I am getting connection issues with one side of the house and want to add a third Satelite. Should I buy an RB50 or...
Jun 22, 2018Guru - Experienced User
The Daisy Chain feature is found on the main routers UI under Advanced tab/Advanced Settings/Wireless Settings. It's just a check mark to enable the feature. No configuration on the satellite needed.
I'm not Darren. :smileywink:
- GizmoguycdnJun 24, 2018Aspirant
Hi ,
Many thanbks for your reply. I have no idea where I saw "darren" and used it thinking it was your name, my apologies.
I just posted a related question on what to buy RBS50 or Nighhawk X4S rane extender to daisy chain to my satelite 2.
- FURRYe38Jun 24, 2018Guru - Experienced User
I replied there too.
