ClintoKL's avatar
ClintoKL
Apprentice
May 25, 2017
Adding a Wired AP such as Unifi
Does anyone know if it is possible to add a wired in wireless AP, such as Unifi ac pro to the Orbi Router or Satellite?   What I mean is run a lan cable from the Router or Satellite to a Unifi AC P...
  • DukeSilver's avatar
    May 25, 2017
    Yes it is possible to connect another AP to a orbi via eithernet and have the other AP on the same SSID.
    You need to have the AP placed exactly right (not too close to the Orbis)  so they do not overlap coverage areas.
    I assume you want to connect another non-Orbi AP to increase wifi coverage with HW that is cheaper than a satellite?
    You still need the Unifi Controller SW installed to configure and manage the AC-Pro.   You can setup the AC-Pro to broadcast in 5GHz dfs channels to avoid inteference.
    Good Luck!
