Arowana's avatar
Arowana
Follower
Sep 29, 2017
Adding additional Satellites
I have setup a Orbi AC3000  with the three units,  One router, and two satellites.
I would like to add three additional satellites.
Is it possible to purchase the same three unit set and use them all as satellites to save a few hundred dollars?
If I purchase three satellites it seems like it would be much more as i cannot find them in packs of three.
Thank you
1 Reply
  • hi
    no you cant use the orbi router in the 3 pack as a sat
    why would you need so many sat's , the 3 pack you purchased covers a huge area and if you had more sat's you would need even more area to put them in as too many says in to close a proximity just over saturates the wifi and makes it all go to crap
