truetken
Dec 11, 2020Aspirant
Adding an additional WIFI router to my existing ORBI system
I have an ORBI system in my home with a router/modem in my basement and a wifi repeater upstairs. The router/modem has the network in port and 3 LAN ports. The repeater upstairs has 4 LAN ports to ...
Dec 11, 2020Guru - Experienced User
What line type did they bury?
If its an ethernet cable, orbi does support wired backhaul
truetken
It was ethernet. So basically I will just need to set up another network in the shop?
- plemansDec 11, 2020Guru - Experienced User
Orbi supports a wired backhaul. so if you already have an orbi setup, you can just add a satellite in the shop and connect it via ethernet.
amazon has been selling the RBS40V for around that $100 lately. satellite in the shop along with a little music.
