JimCoho
Jun 18, 2020Aspirant
adding beyond 3 satellites for orbi ac2200 RBK44- possibly via daisy chain?
Hi, I have an old home with stucco walls and some deadspotes despite my 3 satellites and the router stuck in the basement. I am tired moving my orbi satellites around to accomodate reception. I rea...
Jun 18, 2020Guru - Experienced User
It's possible. Other have posted having 6 RBS connected though didn't mention if Daisy Chain was in the configuration.
JimCoho
Ok thanks. I'll see if any others respond about the daisy chain idea beyond the 3 satellites. are there certain satellites compatible with my older system(2018) that you know about? Thanks
- FURRYe38Jun 18, 2020Guru - Experienced User
RBS20, 30, 40, 50, RBS50Y outdoor, and RBW30s are all compatible.
