jexwin
Mar 10, 2021Aspirant
Adding new streaming devices to Orbi
My wired connection TV and Apple TV are working fine, but a separate TV and Apple TV that are streaming cannot find WIFI. Both have worked in the past, but are now unable to connect. I've tried re-...
CrimpOn
Mar 10, 2021Guru - Experienced User
jexwin wrote:My wired connection TV and Apple TV are working fine, but a separate TV and Apple TV that are streaming cannot find WIFI. Both have worked in the past, but are now unable to connect. I've tried re-connecting via Apple TV's network in settings, but it can't connect to WIFI.
"In the past" as in last week or as in months ago?
"It can't connect" is the AppleTV that is connected to a different television?
One quick test is to set up a Hot Spot using a cell phone and see if the AppleTV will connect to it.
(The AppleTV could be taken to a friend's house and tested on their network and television set.)
I would also verify that Access Control has not been turned on or the AppleTV "paused" with the Orbi "app".
