spatengal
Apr 06, 2020Aspirant
adding outside
Good Morning I have an Orbi RBK 53S. I would like to add an outside satellite. I think the AC 3000 is the correct one. My question is what is the range? Does it need power? If I have a house with a ...
tomschmidt
Apr 06, 2020Virtuoso
The WiFi signal will not travel 200 feet between the router and satellite. To span 200 feet to another building, I suggest adding a Wifi Outdoor Bridge (check Amazon or other retailers). You will need a clear line-of-sight for the two units of a wireless bridge to work. Else, run a buried CAT6 cable the span between your buildings.
