COL_JSims
Sep 22, 2020Aspirant
Adding RBR50 to Existing Network
I wish to install the Orbi solution in a local CPA office. They have an existing network with Cisco router and Cisco switch. The primary purpose for adding the Orbi solution is to enable Wifi connect...
- Sep 22, 2020
As long as you connect the RBS to the back of the RBR, directly or with switches in between the RBR and RBS:
COL_JSims
Thank you for the quick response. I will immediately give this a try. After applying this configuration, will the 2 satellites recognize the base to create the fully meshed wifi that we seek? Both satellites use wired connections, so I would think so since everything will operate on the same IP address range and subnet.
Sep 22, 2020Guru - Experienced User
