estiegel
Nov 24, 2019Tutor
Adding RBS20 to RBR50/RBS50 package - Would this work?
I have a RBR50/RBS50 system that works great but wanted to add one more satelite on the top floor of the house to increase the speed we are getting up there. RBR50 in basement and RBS50 on ground fl...
Nov 24, 2019Guru - Experienced User
you could do either. I'd actually try both to see which would work better.
I prefer the hardwire option but it might reduce the speed the the RBS50 would get on the top floor because its further away. But you won't know until you try both configurations and see which works better.
