elaperche
Sep 26, 2018Follower
Adding RBS50 to RBK50 Tri Band WiFi system
I have th Orbi AC3000 - RBK50 system successfully installed in my home. I am attempting to add the AC300 - RBS50 unit to the configuration and cannot get the satellite unit to connect. I have moved the unit closer to the router without success. Grateful for suggestions on resolution.
1 Reply
What FW is currently loaded?
Is the RBS a new unit that you just bought? If so, the FW needs to be updated on it:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
