arichter11
Jun 07, 2021Tutor
Adding router to exterior garage
Greetings! I have an older Orbi system (I think it's the AC2200 with router and 2 plug-in satellites, but can't honestly remember). We are currently renovating our exterior detached garage and tu...
- Jun 07, 2021
You can use RBS20, RBS40, RBS40v and RBS50 in a ethernet connected configuration:
arichter11
Jun 08, 2021Tutor
Hey quick follow up question (just thought of this). Is it all or nothing? My two existing satellites are connected wirelessly, if I switch to the ethernet set up, do they ALL need to be on Ethernet, or can I keep some of them wireless and my new on the ethernet? The two satellites I have do not have ethernet ports so that would not work for me.
Jun 08, 2021Guru - Experienced User
You can use both. I have a couple satellites hardwired in and other running wireless.
