DanceDate's avatar
DanceDate
Follower
May 29, 2018
adding satelites
Am I able to add an addtional satelite to the RBS50???
  • FURRYe38's avatar
    If you want to daisy chaing satellites, then yet. You'll need to enable Daisy Chain feature on the Orbi router.
  • You can, I did recently.  The satellelite I added was over a year old and had never been used.  It was so old that the firmware update would not work.  Took a bit of trial and error to determine how many updated I could jump.  After manually install two updates, it finally auto updated to the latest one.  After that it has been as rock solid as the rest of my system.
