fatsister
Oct 27, 2022Guide
Adding secondary router
I am needing WIFI in my shop which is 150' behind my house. My house has an Orbi39 router with two satellites but the signal is weak in the shop due to the inability to space the satellites appropr...
Oct 27, 2022Guru - Experienced User
as FURRYe38 says, just use another satellite.
It'll allow you the seamless roaming and probably be cheaper. You can pick up used satellites for fairly reasonable and it can be hardwired in and join the mesh without issues.
That'd be the easiest way to set it up.
fatsister
Oct 27, 2022Guide
My problem is, it's around 120' for access to electricity between the house and the shop. Too far for my satellites to get a solid signal.
