orbi-fan
Feb 17, 2021Aspirant
Adding to my Orbi system
I have the RBK53 system with the RBR50 and 2 of the RBS50 satellites. I would like to add a couple more satellites at odd locations (out in my shed, out on the deck) and am wanting to know which uni...
Feb 18, 2021Guru - Experienced User
The only devices that support the full 1733mbps backhaul are the 50 series. so the RBS50, RBS50Y
The others will work but their backhaul will be the 866mbps. Not a huge issue provided you don't put one in the middle of a daisy chain.
I've use the 50 and 30/40 series together and can't tell which I connect to because I'm usually not saturating the full backhaul speeds.
