jmbrizzo1's avatar
jmbrizzo1
Follower
Jan 24, 2025
Adding used RBS50 to my existing network
Looking for ideas on how to add a used (purchased off Ebay) RBS50 to my existing network. I have tried to reset using the pin hole but no luck getting the amber light. I have "factory reset" the unit...
