MattHopkins
Jan 31, 2017Guide
Additional Orbi Satellite availability in UK?
Does anyone have information / dates on when we can purchase an additional Orbi Satellite to extend our system? I have great coverage for two-thirds of my home and "ok" coverage for the remaining th...
- Feb 03, 2017
Should be available in UK early Q2. Maybe a bit earlier if possible.
DarrenM
timweatherall71
Feb 28, 2017Tutor
can i order a satellite from the US?
I bought a set of two and it doesnt cover my 2500 sq foot house
hence need third.
peteytesting
Feb 28, 2017Hero
timweatherall71 wrote:can i order a satellite from the US?
hence need third.
you have other issues if the orbi router and 1 sat cant cover such a small home , you may want to look at other options like power line adapters etc as i suggest you local construction materials and or environment are not conducive to good wifi propagation
- timweatherall71Feb 28, 2017Tutor
thanks
but could i buy a 2nd satellite from US an dit would work with existing?
- peteytestingMar 01, 2017Hero
yes it would work but you would have to pair it manually and also use a power adapter to convert from usa to uk
- timweatherall71Mar 01, 2017Tutor
thanks
when are UK ones available?
