Rupert22
Aug 07, 2018Aspirant
Additional range extender for ORBI RBK50
I have the RBK50 system - Router + 1 Satellite - and want to extend the wi-fi range to my garage to operate a (wi-fi) outside security camera.
Is the ORBI "wallplug RBW30" the soution - i.e. is it ...
Aug 07, 2018Guru - Experienced User
I believe it is. However I've seen other user post about having problems with the RBW30. Can try it and see. If it doesn't work well for you, go with the RBS.
- Rupert22Aug 08, 2018Aspirant
Many thanks.
However I've since seen numerous reports of ORBI wifi connection problems with my intended Ring Floodlight security camera - which seems to be incompatible. So, it's back to the drawing board.....and further research to find a compatible camera!
R
