joebay
Jul 16, 2020Follower
Additional Satellites for Orbi RBK50
Hi!
I currently have an Orbi Wifi System (RBK50 + 2 RBS50). I plan to add one or two more smaller satellites for two rooms to further enhance the signal. Can the RBS10 work as an additional satellites for my RBK50? I want to make sure before I purchase the RBS10s.
Thank you.
My understanding from the Product Data Sheet is that the RBS10 works only with the RBR10 product. Notice on page 4, "What do I need..?" it says specifically RBR10
https://www.netgear.com/images/datasheet/orbi/RBS10.pdf
The product data sheet for other satellite models claim that they require one of a series of Orbi routers.
Having too many RBS or too much wifi singals may not improve anything and make things worse.
joebay wrote:Hi!
Thank you.
